Ana içeriğe geç
Samsung Gear VR Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: adım 1, 3 resimden 1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: adım 1, 3 resimden 2. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: adım 1, 3 resimden 3.
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: adım 2, 2 resimden 1. Samsung Gear VR  Motherboard Replacement: adım 2, 2 resimden 2.
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: adım 4, 1 resimden 1.
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
Sonuç
David Forlano
119 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G6
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 1,521
