Ana içeriğe geç
Samsung Gear VR Front Phone Mount Replacement
Neye ihtiyacın var
  1. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: adım 1, 3 resimden 1. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: adım 1, 3 resimden 2. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: adım 1, 3 resimden 3.
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Front Phone Mount Replacement: adım 2, 2 resimden 1. Samsung Gear VR Front Phone Mount Replacement: adım 2, 2 resimden 2.
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Garrett Moncrief
179 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G6
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,257
