Ana içeriğe geç
Samsung Gear VR USB Connector Replacement
  1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: adım 1, 1 resimden 1.
    • Remove front cover from headset.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Gear VR USB Connector Replacement: adım 2, 1 resimden 1.
    • Slide the latch to the right to unlock the current connector.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Gear VR USB Connector Replacement: adım 3, 2 resimden 1. Samsung Gear VR USB Connector Replacement: adım 3, 2 resimden 2.
    • Lift connector clip away from headset and towards you.
    • Slide current connector out and away from headset until it is disconnected from connector clip.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Gear VR USB Connector Replacement: adım 4, 1 resimden 1.
    • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
    • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Gear VR USB Connector Replacement: adım 5, 2 resimden 1. Samsung Gear VR USB Connector Replacement: adım 5, 2 resimden 2.
    • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
    • Slide the lock latch to the left to secure the connector into place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alfredo Aparicio
325 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G6, Eyestone Fall 2017 USF Tampa, Team S4-G6, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G6
4 Üyeler
7 adet Kılavuz yazıldı
5Kılavuz Yorumları
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Yanıt Paylaş
Were do I get the USB c adapter
helenpaul77 - Yanıt Paylaş
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron - Yanıt Paylaş
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh - Yanıt Paylaş
Where can I get micro USB converter for gear vr not type c
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 25
Son 30 gün: 93
Her zaman: 18,205
