Ana içeriğe geç
Samsung Gear VR with Controller Inner Mask Replacement
Neye ihtiyacın var
  1. Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: adım 1, 3 resimden 1. Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: adım 1, 3 resimden 2. Samsung Gear VR with Controller Inner Mask Replacement, Inner Mask: adım 1, 3 resimden 3.
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Samsung Gear VR with Controller Inner Mask Replacement: adım 2, 3 resimden 1. Samsung Gear VR with Controller Inner Mask Replacement: adım 2, 3 resimden 2. Samsung Gear VR with Controller Inner Mask Replacement: adım 2, 3 resimden 3.
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
  3. Samsung Gear VR with Controller Inner Mask Replacement: adım 3, 3 resimden 1. Samsung Gear VR with Controller Inner Mask Replacement: adım 3, 3 resimden 2. Samsung Gear VR with Controller Inner Mask Replacement: adım 3, 3 resimden 3.
    • Use a metal spudger to remove the screw cover centered at the top.
  4. Samsung Gear VR with Controller Inner Mask Replacement: adım 4, 3 resimden 1. Samsung Gear VR with Controller Inner Mask Replacement: adım 4, 3 resimden 2. Samsung Gear VR with Controller Inner Mask Replacement: adım 4, 3 resimden 3.
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
  5. Samsung Gear VR with Controller Inner Mask Replacement: adım 5, 2 resimden 1. Samsung Gear VR with Controller Inner Mask Replacement: adım 5, 2 resimden 2.
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
  6. Samsung Gear VR with Controller Inner Mask Replacement: adım 6, 2 resimden 1. Samsung Gear VR with Controller Inner Mask Replacement: adım 6, 2 resimden 2.
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
  7. Samsung Gear VR with Controller Inner Mask Replacement: adım 7, 3 resimden 1. Samsung Gear VR with Controller Inner Mask Replacement: adım 7, 3 resimden 2. Samsung Gear VR with Controller Inner Mask Replacement: adım 7, 3 resimden 3.
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
  8. Samsung Gear VR with Controller Inner Mask Replacement: adım 8, 3 resimden 1. Samsung Gear VR with Controller Inner Mask Replacement: adım 8, 3 resimden 2. Samsung Gear VR with Controller Inner Mask Replacement: adım 8, 3 resimden 3.
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Harumi Hokari
243 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, White Winter 2019 Cal Poly, Team S18-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S18G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 282
