Ana içeriğe geç
Samsung Gear VR with Controller Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: adım 1, 3 resimden 1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: adım 1, 3 resimden 2. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: adım 1, 3 resimden 3.
    • Turn the controller upside down to access the battery compartment.
    • The battery compartment is located on the opposite side of the buttons.
    • Press on the top of the battery plate and slide down to remove the cover.
  2. Samsung Gear VR with Controller Motherboard Replacement: adım 2, 3 resimden 1. Samsung Gear VR with Controller Motherboard Replacement: adım 2, 3 resimden 2. Samsung Gear VR with Controller Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the AAA batteries using your fingers.
  3. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: adım 3, 2 resimden 1. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: adım 3, 2 resimden 2.
    • Remove the four 5mm Phillips #000 screws.
  4. Samsung Gear VR with Controller Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the metal spudger to pry the back side of the controller apart from the front.
    • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
  5. Samsung Gear VR with Controller Motherboard Replacement: adım 5, 2 resimden 1. Samsung Gear VR with Controller Motherboard Replacement: adım 5, 2 resimden 2.
    • Pull apart the two halves of the controller to access the motherboard.
  6. Samsung Gear VR with Controller Motherboard Replacement: adım 6, 3 resimden 1. Samsung Gear VR with Controller Motherboard Replacement: adım 6, 3 resimden 2. Samsung Gear VR with Controller Motherboard Replacement: adım 6, 3 resimden 3.
    • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
    • Separate the motherboard and trackpad from the rear part of the controller.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jake Criscione
587 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G3, White Winter 2019 Cal Poly, Team S18-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S18G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 953
