Ana içeriğe geç
Giriş
This guide will provide a step by step procedure for installing the internal antenna.
  1. Using your thumb, press down and slide the back cover away from the  camera.
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together. Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
    • Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
  5. Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap. Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap.
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  6. The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends. Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
    • The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends.
    • Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
  7. Using a plastic opening tool, disconnect the connector leading from the antenna to the phone. Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
    • Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
Sonuç
Cameron Law
142 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G12
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 984
