Ana içeriğe geç
Samsung Glyde Keyboard Replacement
Neye ihtiyacın var
  1. Samsung Glyde Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Using your thumb, press down and slide the back cover away from the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Glyde Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Glyde Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. Samsung Glyde Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the six 4mm screws.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Glyde Keyboard Replacement: adım 4, 2 resimden 1. Samsung Glyde Keyboard Replacement: adım 4, 2 resimden 2.
    • Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure to slowly maneuver around until the case is pryed apart.
    • Take the case off with your fingers
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Glyde Keyboard Replacement: adım 5, 2 resimden 1. Samsung Glyde Keyboard Replacement: adım 5, 2 resimden 2.
    • The green film is located above the camera. It is the camera connector to the motherboard.
    • Disconnect the camera connector with the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Glyde Keyboard Replacement: adım 6, 2 resimden 1. Samsung Glyde Keyboard Replacement: adım 6, 2 resimden 2.
    • Take a close up of the picture for this step for a better view.
    • Use a plastic opening tool to disconnect the keyboard connector.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Glyde Keyboard Replacement: adım 7, 2 resimden 1. Samsung Glyde Keyboard Replacement: adım 7, 2 resimden 2.
    • The motherboard is held in place by the circular connector.
    • Using a plastic opening tool, disconnect the circular connector.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Glyde Keyboard Replacement: adım 8, 3 resimden 1. Samsung Glyde Keyboard Replacement: adım 8, 3 resimden 2. Samsung Glyde Keyboard Replacement: adım 8, 3 resimden 3.
    • A LCD connector is located underneath the motherboard.
    • Lift the far edge of the motherboard gently upwards toward the center.
    • Using a plastic opening tool, disconnect the LCD connector.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Glyde Keyboard Replacement: adım 9, 2 resimden 1. Samsung Glyde Keyboard Replacement: adım 9, 2 resimden 2.
    • Lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Glyde Keyboard Replacement: adım 10, 3 resimden 1. Samsung Glyde Keyboard Replacement: adım 10, 3 resimden 2. Samsung Glyde Keyboard Replacement: adım 10, 3 resimden 3.
    • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
    • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
    • With your hands finish prying apart the antenna by lifting it up.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Glyde Keyboard Replacement: adım 11, 2 resimden 1. Samsung Glyde Keyboard Replacement: adım 11, 2 resimden 2.
    • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Cameron Law
142 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G12
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 1,570
