Ana içeriğe geç
Samsung Glyde Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Glyde Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Using your thumb, press down and slide the back cover away from the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Glyde Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Glyde Motherboard Replacement, Motherboard: adım 3, 2 resimden 1. Samsung Glyde Motherboard Replacement, Motherboard: adım 3, 2 resimden 2.
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Glyde Motherboard Replacement: adım 4, 2 resimden 1. Samsung Glyde Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Glyde Motherboard Replacement: adım 5, 2 resimden 1. Samsung Glyde Motherboard Replacement: adım 5, 2 resimden 2.
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Glyde Motherboard Replacement: adım 6, 2 resimden 1. Samsung Glyde Motherboard Replacement: adım 6, 2 resimden 2.
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Glyde Motherboard Replacement: adım 7, 2 resimden 1. Samsung Glyde Motherboard Replacement: adım 7, 2 resimden 2.
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Glyde Motherboard Replacement: adım 8, 3 resimden 1. Samsung Glyde Motherboard Replacement: adım 8, 3 resimden 2. Samsung Glyde Motherboard Replacement: adım 8, 3 resimden 3.
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Glyde Motherboard Replacement: adım 9, 2 resimden 1. Samsung Glyde Motherboard Replacement: adım 9, 2 resimden 2.
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Stephen
26 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 3-12, Regan Fall 2011 Cal Poly, Team 3-12, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G12
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 1,493
