Ana içeriğe geç
Samsung Gravity SGH-T669 Front Glass Assembly Replacement
Neye ihtiyacın var
  1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: adım 1, 3 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: adım 1, 3 resimden 2. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure your phone is powered off.
    • Use a plastic opening tool to remove the rear battery cover.
  2. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 2, 2 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pulling up from the bottom right corner.
    • Remove the SIM card and the Micro SD card.
    • SIM card
    • Micro SD card
  3. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Casing: adım 3, 1 resimden 1.
    • Remove the six 2.8 mm Phillips screws.
  4. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 4, 3 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 4, 3 resimden 2. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to pry off the casing.
    • The volume button, camera button, and lock button may fall out as you remove the casing. If they are still on the phone, remove them.
    • Lock button
    • Camera button
    • Volume button
  5. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Motherboard: adım 5, 2 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Motherboard: adım 5, 2 resimden 2.
    • Disconnect the LCD cable with a plastic opening tool.
    • Remove the two 2.8 mm Phillips screws that hold the motherboard in place.
  6. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 6, 1 resimden 1.
    • Remove motherboard.
  7. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Separating the halves: adım 7, 2 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Separating the halves: adım 7, 2 resimden 2.
    • Remove the six 1.5 mm Phillips screws.
    • Very gently peel the LCD cord off the slider assembly.
  8. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 8, 1 resimden 1.
    • Remove the keyboard housing from the screen housing.
  9. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Screen casing: adım 9, 1 resimden 1.
    • Remove the four 2.5 mm Phillips screws.
  10. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 10, 3 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 10, 3 resimden 2. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 10, 3 resimden 3.
    • I found that my plastic opening tool wasn't strong enough (it broke) to pry open this casing.
    • I used a 1.3 mm Flathead screwdriver as an opening tool.
    • After you have gotten under the edge of the back plate, slide your tool along the length of the plate.
    • Be careful if using a screwdriver to open the casing. While there are a minimal amount of components that can be damaged, caution should be exercised. It is not recommended.
  11. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 11, 2 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 11, 2 resimden 2.
    • Remove the cover.
    • There are four clips on the underside of the cover, shown in the green and yellow boxes.
    • I found these clips to be the hardest to remove.
    • After removing the yellow clips, these should follow easily.
  12. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Remove the LCD: adım 12, 2 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement, Remove the LCD: adım 12, 2 resimden 2.
    • It's time to take the LCD out.
    • Begin by removing the blue piece of tape.
  13. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 13, 2 resimden 1. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 13, 2 resimden 2.
    • Disconnect the two ZIF connections using a plastic opening tool.
    • ZIF #1
    • ZIF #2
  14. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 14, 1 resimden 1.
    • Use a plastic opening tool on the bottom of the LCD to pry it off.
  15. Samsung Gravity SGH-T669 Front Glass Assembly Replacement: adım 15, 1 resimden 1.
    • Remove the LCD panel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew Schneider
970 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,305
