Ana içeriğe geç
Samsung Gravity TXT microSD Card Replacement
Neye ihtiyacın var
  1. Samsung Gravity TXT microSD Card  Replacement, Battery: adım 1, 2 resimden 1. Samsung Gravity TXT microSD Card  Replacement, Battery: adım 1, 2 resimden 2.
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Gravity TXT microSD Card  Replacement: adım 2, 1 resimden 1.
    • Lift the back cover away from the main body of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Gravity TXT microSD Card  Replacement: adım 3, 1 resimden 1.
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Gravity TXT microSD Card  Replacement, microSD Card: adım 4, 3 resimden 1. Samsung Gravity TXT microSD Card  Replacement, microSD Card: adım 4, 3 resimden 2. Samsung Gravity TXT microSD Card  Replacement, microSD Card: adım 4, 3 resimden 3.
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Mounir Karmada
465 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Renguette SU 2015 IUPUI, Team 1-1, Renguette SU 2015 üyesi
IUPUI-RENGUETTE-SU15S1G1
5 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 461
