Ana içeriğe geç
Samsung Gravity TXT microSD Card Replacement
Neye ihtiyacın var
  1. Samsung Gravity TXT microSD Card  Replacement, Battery: adım 1, 2 resimden 1. Samsung Gravity TXT microSD Card  Replacement, Battery: adım 1, 2 resimden 2.
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT microSD Card  Replacement: adım 2, 1 resimden 1.
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT microSD Card  Replacement: adım 3, 1 resimden 1.
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT microSD Card  Replacement, microSD Card: adım 4, 3 resimden 1. Samsung Gravity TXT microSD Card  Replacement, microSD Card: adım 4, 3 resimden 2. Samsung Gravity TXT microSD Card  Replacement, microSD Card: adım 4, 3 resimden 3.
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
Sonuç
Mounir Karmada
465 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Renguette SU 2015 IUPUI, Team 1-1, Renguette SU 2015 üyesi
IUPUI-RENGUETTE-SU15S1G1
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 203
