Ana içeriğe geç
Samsung HD Pro Camera Lens Replacement
Neye ihtiyacın var
    1. Samsung HD Pro Camera Lens Replacement, Casing: adım 1, 1 resimden 1.
      • Locate a small opening around the front panel of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung HD Pro Camera Lens Replacement: adım 2, 1 resimden 1.
      • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung HD Pro Camera Lens Replacement: adım 3, 1 resimden 1.
      • Remove both of the connecting wires from the motherboard.
      • Be careful to not bend headers or damage the wires.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung HD Pro Camera Lens Replacement: adım 4, 1 resimden 1.
      • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung HD Pro Camera Lens Replacement: adım 5, 1 resimden 1.
      • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung HD Pro Camera Lens Replacement, Camera Lens: adım 6, 1 resimden 1.
      • Locate the camera lens and unscrew it with your hands.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung HD Pro Camera Lens Replacement: adım 7, 1 resimden 1.
      • Remove the washers between the lens and motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Hunter Wood
101 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Where do you purchase a new lens?
Gary - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 1,184
