Ana içeriğe geç
Samsung HD Pro LED Light Ring Replacement
Neye ihtiyacın var
  1. Samsung HD Pro LED Light Ring Replacement, Casing: adım 1, 1 resimden 1.
    • Locate a small opening around the front panel of the camera.
  2. Samsung HD Pro LED Light Ring Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung HD Pro LED Light Ring Replacement: adım 3, 1 resimden 1.
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung HD Pro LED Light Ring Replacement: adım 4, 1 resimden 1.
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung HD Pro LED Light Ring Replacement: adım 5, 1 resimden 1.
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
  6. Samsung HD Pro LED Light Ring Replacement, LED Light Ring: adım 6, 1 resimden 1.
    • Locate the small circuit board surrounding the lens in the removed front portion of the device.
  7. Samsung HD Pro LED Light Ring Replacement: adım 7, 1 resimden 1.
    • Push the four white tabs away from the center of the lens housing while pulling the led ring up near each tab.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 464
