Ana içeriğe geç
Samsung HMX-F90 LCD Screen Replacement
Neye ihtiyacın var
  1. Samsung HMX-F90 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 1. Samsung HMX-F90 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 2.
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  2. Samsung HMX-F90 LCD Screen Replacement: adım 2, 2 resimden 1. Samsung HMX-F90 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  3. Samsung HMX-F90 LCD Screen Replacement: adım 3, 2 resimden 1. Samsung HMX-F90 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Rotate the camcorder so that it is facing you.
    • Locate and remove the two 4.5mm Phillips #00 screws.
  4. Samsung HMX-F90 LCD Screen Replacement: adım 4, 3 resimden 1. Samsung HMX-F90 LCD Screen Replacement: adım 4, 3 resimden 2. Samsung HMX-F90 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Open the LCD screen and rotate it around 90 degrees.
    • Locate the small prying notch and use a prying tool to slowly remove the LCD cover.
  5. Samsung HMX-F90 LCD Screen Replacement: adım 5, 3 resimden 1. Samsung HMX-F90 LCD Screen Replacement: adım 5, 3 resimden 2. Samsung HMX-F90 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Locate and remove the two 3.5mm Phillips #00 screws holding the back cover.
  6. Samsung HMX-F90 LCD Screen Replacement: adım 6, 3 resimden 1. Samsung HMX-F90 LCD Screen Replacement: adım 6, 3 resimden 2. Samsung HMX-F90 LCD Screen Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With tweezers gently unclip the silver tab holding the ribbon wire.
    • Gradually feed the ribbon wire through the hole to remove the screen.
Sonuç
Amir Harb
705 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G1, Boczar Fall 2017 USF Tampa, Team S13-G1, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S13G1
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
How can I buy the LCD??
Mike - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,255
