Ana içeriğe geç
Samsung HMX-F90 Record Button Replacement
Neye ihtiyacın var
    1. Samsung HMX-F90 Record Button Replacement, Battery: adım 1, 3 resimden 1. Samsung HMX-F90 Record Button Replacement, Battery: adım 1, 3 resimden 2. Samsung HMX-F90 Record Button Replacement, Battery: adım 1, 3 resimden 3.
      • Pull the release tab away from the battery.
      • Slide the battery towards the release tab and then pull the battery away from the camcorder.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung HMX-F90 Record Button Replacement, Strap Side Outer Casing: adım 2, 2 resimden 1. Samsung HMX-F90 Record Button Replacement, Strap Side Outer Casing: adım 2, 2 resimden 2.
      • Rotate the camcorder so that the strap side is facing you.
      • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung HMX-F90 Record Button Replacement: adım 3, 2 resimden 1. Samsung HMX-F90 Record Button Replacement: adım 3, 2 resimden 2.
      • Rotate the camcorder so that the battery slot is facing you.
      • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung HMX-F90 Record Button Replacement: adım 4, 2 resimden 1. Samsung HMX-F90 Record Button Replacement: adım 4, 2 resimden 2.
      • Rotate the camcorder so you are looking at the bottom of the camcorder.
      • Locate and remove the last three 4.5mm Phillips #00 screws.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung HMX-F90 Record Button Replacement: adım 5, 3 resimden 1. Samsung HMX-F90 Record Button Replacement: adım 5, 3 resimden 2. Samsung HMX-F90 Record Button Replacement: adım 5, 3 resimden 3.
      • With both hands, pull the side strap apart from the rest of the camcorder.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung HMX-F90 Record Button Replacement, Record Button: adım 6, 3 resimden 1. Samsung HMX-F90 Record Button Replacement, Record Button: adım 6, 3 resimden 2. Samsung HMX-F90 Record Button Replacement, Record Button: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Locate plastic clips of the record button.
      • With tweezers squeeze together the two plastic clips and push the button out.
      • Wiggle and pull the record button to remove completely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Amir Harb
705 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G1, Boczar Fall 2017 USF Tampa, Team S13-G1, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S13G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 44
Her zaman: 691
