Ana içeriğe geç
Samsung HMX-F90 Strap Side Outer Casing Replacement
Neye ihtiyacın var
  1. Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: adım 1, 3 resimden 1. Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: adım 1, 3 resimden 2. Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: adım 1, 3 resimden 3.
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Strap Side Outer Casing Replacement, Strap Side Outer Casing: adım 2, 2 resimden 1. Samsung HMX-F90 Strap Side Outer Casing Replacement, Strap Side Outer Casing: adım 2, 2 resimden 2.
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Strap Side Outer Casing Replacement: adım 3, 2 resimden 1. Samsung HMX-F90 Strap Side Outer Casing Replacement: adım 3, 2 resimden 2.
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Strap Side Outer Casing Replacement: adım 4, 2 resimden 1. Samsung HMX-F90 Strap Side Outer Casing Replacement: adım 4, 2 resimden 2.
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Strap Side Outer Casing Replacement: adım 5, 3 resimden 1. Samsung HMX-F90 Strap Side Outer Casing Replacement: adım 5, 3 resimden 2. Samsung HMX-F90 Strap Side Outer Casing Replacement: adım 5, 3 resimden 3.
    • With both hands, pull the side strap apart from the rest of the camcorder.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Amir Harb
705 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G1, Boczar Fall 2017 USF Tampa, Team S13-G1, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S13G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 366
