Ana içeriğe geç
Samsung HMX-QF20 Lens Replacement
Neye ihtiyacın var
  1. Samsung HMX-QF20 Lens Replacement, Lens: adım 1, 1 resimden 1.
    • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
  2. Samsung HMX-QF20 Lens Replacement: adım 2, 1 resimden 1.
    • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
  3. Samsung HMX-QF20 Lens Replacement: adım 3, 1 resimden 1.
    • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
  4. Samsung HMX-QF20 Lens Replacement: adım 4, 1 resimden 1.
    • Firmly grip and pull the front casing on the lens to remove it.
    • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
  5. Samsung HMX-QF20 Lens Replacement: adım 5, 1 resimden 1.
    • Remove the three 5 mm screws surrounding the lens.
Sonuç
Renee
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team 1-5, Laflen Spring 2015 Marist, Team 1-5, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G5
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 592
