Giriş
For the user to remove the camera lens of the Samsung HMX-W200, they will first need to remove the components protecting the lens.
Neye ihtiyacın var
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Bu adımda kullanılan alet:Tweezers$4.99
Use the precision tweezers, to gently pull and remove the connector connecting lens and motherboard.
