Ana içeriğe geç
Samsung HMX-W200 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung HMX-W200 Motherboard Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
  2. Samsung HMX-W200 Motherboard Replacement: adım 2, 3 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 2, 3 resimden 2. Samsung HMX-W200 Motherboard Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
    • Make sure to separate all the corners before removing the red casing.
  3. Samsung HMX-W200 Motherboard Replacement: adım 3, 2 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
  4. Samsung HMX-W200 Motherboard Replacement: adım 4, 2 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 4, 2 resimden 2.
    • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
    • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
  5. Samsung HMX-W200 Motherboard Replacement: adım 5, 2 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
  6. Samsung HMX-W200 Motherboard Replacement: adım 6, 2 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
  7. Samsung HMX-W200 Motherboard Replacement: adım 7, 3 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 7, 3 resimden 2. Samsung HMX-W200 Motherboard Replacement: adım 7, 3 resimden 3.
    • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
  8. Samsung HMX-W200 Motherboard Replacement: adım 8, 1 resimden 1.
    • Separate the front and back casing.
  9. Samsung HMX-W200 Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Once inside the device, find the half that contains the motherboard of the device.
  10. Samsung HMX-W200 Motherboard Replacement: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use precision tweezers to gently pull out the USB connection from the motherboard.
  11. Samsung HMX-W200 Motherboard Replacement: adım 11, 2 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the audio connector from the motherboard (red and black cables).
    • Using the plastic opening tool, lift the connectors from all sides before pulling it with your fingers.
    • Do not pull off the connectors by the cables. This could damage the connection from the speaker to the motherboard.
  12. Samsung HMX-W200 Motherboard Replacement: adım 12, 2 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 12, 2 resimden 2.
    • Use precision tweezers to remove the connector joining the LCD and the motherboard.
  13. Samsung HMX-W200 Motherboard Replacement: adım 13, 2 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the six 2.00mm screws with Phillips #00 screwdriver.
  14. Samsung HMX-W200 Motherboard Replacement: adım 14, 3 resimden 1. Samsung HMX-W200 Motherboard Replacement: adım 14, 3 resimden 2. Samsung HMX-W200 Motherboard Replacement: adım 14, 3 resimden 3.
    • Lift motherboard from top left side and pull away gently.
Sonuç
Haya Barakat
521 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-6, Sullivan Fall 2016 USF Tampa, Team 3-6, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S3G6
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 193
