Giriş
Demonstrates how to replace the front case of the camera through pictures and words. Replacement of the rear case requires disassembling battery housing and battery from front case.
Neye ihtiyacın var
To remove the wristband of the device, grab the middle loop and pull the band through.
Remove the four screws from the battery housing using a Phillips #00 screwdriver.
Bu adımda kullanılan alet:Tweezers$4.99
Use an iFixit opening tool to pry up the plastic cover.
Use tweezers to remove the wire from the slots.
