Ana içeriğe geç
Samsung HMX-W300 LCD Screen Replacement
Neye ihtiyacın var
    1. Samsung HMX-W300 LCD Screen Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 3.
      • To remove the wristband of the device, grab the middle loop and pull the band through.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung HMX-W300 LCD Screen Replacement: adım 2, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 2, 2 resimden 2.
      • Remove four screws with a Hex 1.5 mm screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung HMX-W300 LCD Screen Replacement: adım 3, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 3, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement: adım 3, 3 resimden 3.
      • Open the HDMI door on the side of the camera.
      • Remove the single screw using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung HMX-W300 LCD Screen Replacement: adım 4, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 4, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement: adım 4, 3 resimden 3.
      • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
      • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung HMX-W300 LCD Screen Replacement: adım 5, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 5, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Pull the wire ribbon out with a pair of tweezers.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung HMX-W300 LCD Screen Replacement, Remove tape.: adım 6, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Remove tape.: adım 6, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement, Remove tape.: adım 6, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung HMX-W300 LCD Screen Replacement, Unplug wire ribbon.: adım 7, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Unplug wire ribbon.: adım 7, 2 resimden 2.
      • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung HMX-W300 LCD Screen Replacement, Remove scerws.: adım 8, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Remove scerws.: adım 8, 2 resimden 2.
      • There are 5 Phillips size 00 screws. Remove all 5 screws.
      • Wire ribbon is attached to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung HMX-W300 LCD Screen Replacement: adım 9, 1 resimden 1.
      • Pry the motherboard up using the plastic opening tool.
      • Be careful there is a wire ribbon holding the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung HMX-W300 LCD Screen Replacement, Disconnect wire ribbon.: adım 10, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Disconnect wire ribbon.: adım 10, 2 resimden 2.
      • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung HMX-W300 LCD Screen Replacement, Remove screws.: adım 11, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Remove screws.: adım 11, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement, Remove screws.: adım 11, 3 resimden 3.
      • Use Phillips size 00 and remove the 3 screws as shown.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung HMX-W300 LCD Screen Replacement, Pry screen.: adım 12, 2 resimden 1. Samsung HMX-W300 LCD Screen Replacement, Pry screen.: adım 12, 2 resimden 2.
      • Pry the end of the screen with the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung HMX-W300 LCD Screen Replacement: adım 13, 3 resimden 1. Samsung HMX-W300 LCD Screen Replacement: adım 13, 3 resimden 2. Samsung HMX-W300 LCD Screen Replacement: adım 13, 3 resimden 3.
      • Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert
966 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Blackwell Winter 2015 USF Tampa, Team 9-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S9G2
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 31
Her zaman: 805
