Ana içeriğe geç
Samsung HMX-W300 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung HMX-W300 Motherboard Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 1. Samsung HMX-W300 Motherboard Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 2. Samsung HMX-W300 Motherboard Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 3.
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Motherboard Replacement: adım 2, 2 resimden 1. Samsung HMX-W300 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Motherboard Replacement: adım 3, 3 resimden 1. Samsung HMX-W300 Motherboard Replacement: adım 3, 3 resimden 2. Samsung HMX-W300 Motherboard Replacement: adım 3, 3 resimden 3.
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Motherboard Replacement: adım 4, 3 resimden 1. Samsung HMX-W300 Motherboard Replacement: adım 4, 3 resimden 2. Samsung HMX-W300 Motherboard Replacement: adım 4, 3 resimden 3.
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Motherboard Replacement: adım 5, 3 resimden 1. Samsung HMX-W300 Motherboard Replacement: adım 5, 3 resimden 2. Samsung HMX-W300 Motherboard Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Motherboard Replacement, Remove tape.: adım 6, 3 resimden 1. Samsung HMX-W300 Motherboard Replacement, Remove tape.: adım 6, 3 resimden 2. Samsung HMX-W300 Motherboard Replacement, Remove tape.: adım 6, 3 resimden 3.
  7. Samsung HMX-W300 Motherboard Replacement, Unplug wire ribbon.: adım 7, 2 resimden 1. Samsung HMX-W300 Motherboard Replacement, Unplug wire ribbon.: adım 7, 2 resimden 2.
    • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  8. Samsung HMX-W300 Motherboard Replacement, Remove scerws.: adım 8, 2 resimden 1. Samsung HMX-W300 Motherboard Replacement, Remove scerws.: adım 8, 2 resimden 2.
    • There are 5 Phillips size 00 screws. Remove all 5 screws.
    • Wire ribbon is attached to the motherboard.
  9. Samsung HMX-W300 Motherboard Replacement: adım 9, 1 resimden 1.
    • Pry the motherboard up using the plastic opening tool.
    • Be careful there is a wire ribbon holding the motherboard.
  10. Samsung HMX-W300 Motherboard Replacement, Disconnect wire ribbon.: adım 10, 2 resimden 1. Samsung HMX-W300 Motherboard Replacement, Disconnect wire ribbon.: adım 10, 2 resimden 2.
    • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert
966 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Blackwell Winter 2015 USF Tampa, Team 9-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S9G2
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 356
