Giriş
Demonstrates how to replace the rear case of the camera through instructive pictures and words. Replacement of rear case requires the removal of the motherboard and LCD screen.
Neye ihtiyacın var
To remove the wristband of the device, grab the middle loop and pull the band through.
Use tweezers to grab the wire ribbon, then pull the wire out of connection.
There are 5 Phillips size 00 screws. Remove all 5 screws.
Wire ribbon is attached to the motherboard.
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
