Ana içeriğe geç
Samsung HMX-W300 USB Port Replacement
Neye ihtiyacın var
  1. Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 1. Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 2. Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: adım 1, 3 resimden 3.
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 USB Port Replacement: adım 2, 2 resimden 1. Samsung HMX-W300 USB Port Replacement: adım 2, 2 resimden 2.
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 USB Port Replacement: adım 3, 3 resimden 1. Samsung HMX-W300 USB Port Replacement: adım 3, 3 resimden 2. Samsung HMX-W300 USB Port Replacement: adım 3, 3 resimden 3.
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 USB Port Replacement: adım 4, 3 resimden 1. Samsung HMX-W300 USB Port Replacement: adım 4, 3 resimden 2. Samsung HMX-W300 USB Port Replacement: adım 4, 3 resimden 3.
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 USB Port Replacement: adım 5, 3 resimden 1. Samsung HMX-W300 USB Port Replacement: adım 5, 3 resimden 2. Samsung HMX-W300 USB Port Replacement: adım 5, 3 resimden 3.
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 USB Port Replacement, Battery: adım 6, 2 resimden 1. Samsung HMX-W300 USB Port Replacement, Battery: adım 6, 2 resimden 2.
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 USB Port Replacement: adım 7, 1 resimden 1.
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 USB Port Replacement: adım 8, 3 resimden 1. Samsung HMX-W300 USB Port Replacement: adım 8, 3 resimden 2. Samsung HMX-W300 USB Port Replacement: adım 8, 3 resimden 3.
    • After removing the battery housing, take the battery out.
  9. Samsung HMX-W300 USB Port Replacement, USB Port: adım 9, 3 resimden 1. Samsung HMX-W300 USB Port Replacement, USB Port: adım 9, 3 resimden 2. Samsung HMX-W300 USB Port Replacement, USB Port: adım 9, 3 resimden 3.
    • Use an iFixit opening tool to pry up the plastic cover.
    • Use tweezers to remove the wire from the slots.
  10. Samsung HMX-W300 USB Port Replacement: adım 10, 2 resimden 1. Samsung HMX-W300 USB Port Replacement: adım 10, 2 resimden 2.
    • Remove both screws from the USB port using a Phillips #00 screwdriver.
  11. Samsung HMX-W300 USB Port Replacement: adım 11, 2 resimden 1. Samsung HMX-W300 USB Port Replacement: adım 11, 2 resimden 2.
    • Push the USB port inside the case to remove it from the device.
Sonuç
Robert
966 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Blackwell Winter 2015 USF Tampa, Team 9-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S9G2
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 418
