Ana içeriğe geç
Samsung Impression Back Cover Replacement
Neye ihtiyacın var
    1. Samsung Impression Back Cover Replacement, Battery: adım 1, 1 resimden 1.
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Impression Back Cover Replacement: adım 2, 2 resimden 1. Samsung Impression Back Cover Replacement: adım 2, 2 resimden 2.
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Impression Back Cover Replacement, Back Cover: adım 3, 1 resimden 1.
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Impression Back Cover Replacement: adım 4, 1 resimden 1.
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Saul Villatoro
260 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G10
4 Üyeler
99 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 2,092
