Ana içeriğe geç
Samsung Impression Keyboard Replacement
Neye ihtiyacın var
    1. Samsung Impression Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Impression Keyboard Replacement: adım 2, 2 resimden 1. Samsung Impression Keyboard Replacement: adım 2, 2 resimden 2.
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Impression Keyboard Replacement, Back Cover: adım 3, 1 resimden 1.
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Impression Keyboard Replacement: adım 4, 1 resimden 1.
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Impression Keyboard Replacement, Circuit Board: adım 5, 1 resimden 1.
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Impression Keyboard Replacement: adım 6, 2 resimden 1. Samsung Impression Keyboard Replacement: adım 6, 2 resimden 2.
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Impression Keyboard Replacement, Antenna: adım 7, 2 resimden 1. Samsung Impression Keyboard Replacement, Antenna: adım 7, 2 resimden 2.
      • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
      • The antenna assembly will snap off.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Impression Keyboard Replacement, Keyboard: adım 8, 1 resimden 1.
      • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
      • The screws are 2.7mm in length.
      • The bottom black end cap will snap out.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Impression Keyboard Replacement: adım 9, 2 resimden 1. Samsung Impression Keyboard Replacement: adım 9, 2 resimden 2.
      • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
      • Separate the silver plate and phone frame (fig. 2).
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Impression Keyboard Replacement: adım 10, 1 resimden 1.
      • The silver piece you are left with is the physical keyboard assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ross McKelvie
196 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G10
4 Üyeler
99 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 2,709
