Ana içeriğe geç
Samsung Instinct Antenna Replacement
Neye ihtiyacın var
  1. Samsung Instinct Antenna Replacement, Battery: adım 1, 1 resimden 1.
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Instinct Antenna Replacement: adım 2, 1 resimden 1.
    • Holding the phone firmly, use the notches to grip and lift up the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Instinct Antenna Replacement, Back Case: adım 3, 1 resimden 1.
    • Remove the four 4.45mm screws at the corners of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Instinct Antenna Replacement: adım 4, 2 resimden 1. Samsung Instinct Antenna Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Instinct Antenna Replacement: adım 5, 1 resimden 1.
    • Lift the casing off of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Instinct Antenna Replacement, Antenna: adım 6, 1 resimden 1.
    • With the screws removed, locate the antenna.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Instinct Antenna Replacement: adım 7, 1 resimden 1.
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Instinct Antenna Replacement: adım 8, 1 resimden 1.
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Instinct Antenna Replacement: adım 9, 1 resimden 1.
    • Gently lift up on the antenna and remove it from the back of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jimmy Kuo
14 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G13
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 1,339
