Ana içeriğe geç
Samsung Instinct Back Case Replacement
Neye ihtiyacın var
    1. Samsung Instinct Back Case Replacement, Battery: adım 1, 1 resimden 1.
      • Apply pressure to the back cover and slide it forward towards the camera.
      • Lift the back cover off the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Instinct Back Case Replacement: adım 2, 1 resimden 1.
      • Holding the phone firmly, use the notches to grip and lift up the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Instinct Back Case Replacement, Back Case: adım 3, 1 resimden 1.
      • Remove the four 4.45mm screws at the corners of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Instinct Back Case Replacement: adım 4, 2 resimden 1. Samsung Instinct Back Case Replacement: adım 4, 2 resimden 2.
      • Use the plastic opening tool to unhinge the locks around the edges of the phone.
      • Do not worry about the inner components of the phone; they are not connected to this case.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Instinct Back Case Replacement: adım 5, 1 resimden 1.
      • Lift the casing off of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jacob Michener
31 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G13
4 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 1,276
