Ana içeriğe geç
Samsung Instinct Camera Replacement
Neye ihtiyacın var
    1. Samsung Instinct Camera Replacement, Battery: adım 1, 1 resimden 1.
      • Apply pressure to the back cover and slide it forward towards the camera.
      • Lift the back cover off the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Instinct Camera Replacement: adım 2, 1 resimden 1.
      • Holding the phone firmly, use the notches to grip and lift up the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Instinct Camera Replacement, Back Case: adım 3, 1 resimden 1.
      • Remove the four 4.45mm screws at the corners of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Instinct Camera Replacement: adım 4, 2 resimden 1. Samsung Instinct Camera Replacement: adım 4, 2 resimden 2.
      • Use the plastic opening tool to unhinge the locks around the edges of the phone.
      • Do not worry about the inner components of the phone; they are not connected to this case.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Instinct Camera Replacement: adım 5, 1 resimden 1.
      • Lift the casing off of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Instinct Camera Replacement, Antenna: adım 6, 1 resimden 1.
      • With the screws removed, locate the antenna.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Instinct Camera Replacement: adım 7, 1 resimden 1.
      • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Instinct Camera Replacement: adım 8, 1 resimden 1.
      • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Instinct Camera Replacement: adım 9, 1 resimden 1.
      • Gently lift up on the antenna and remove it from the back of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Instinct Camera Replacement, Front Case: adım 10, 1 resimden 1.
      • Remove the two 3.50mm screws connecting the motherboard to the case.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Instinct Camera Replacement: adım 11, 3 resimden 1. Samsung Instinct Camera Replacement: adım 11, 3 resimden 2. Samsung Instinct Camera Replacement: adım 11, 3 resimden 3.
      • Use the plastic opener tool to detach the three ribbons on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Instinct Camera Replacement: adım 12, 1 resimden 1.
      • Lift out the top right ribbon from its slot on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Instinct Camera Replacement: adım 13, 2 resimden 1. Samsung Instinct Camera Replacement: adım 13, 2 resimden 2.
      • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Instinct Camera Replacement: adım 14, 1 resimden 1.
      • Lift the motherboard away from the front casing.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Instinct Camera Replacement: adım 15, 1 resimden 1.
      • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Instinct Camera Replacement, Motherboard: adım 16, 3 resimden 1. Samsung Instinct Camera Replacement, Motherboard: adım 16, 3 resimden 2. Samsung Instinct Camera Replacement, Motherboard: adım 16, 3 resimden 3.
      • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
      • There are three strips total: one on the right, left, and top of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Instinct Camera Replacement: adım 17, 1 resimden 1.
      • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Instinct Camera Replacement: adım 18, 1 resimden 1.
      • Using the plastic opener tool, remove the speaker from its setting.
      • Pry where the wire enters the speaker.
      • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Instinct Camera Replacement: adım 19, 1 resimden 1.
      • Gently lift the motherboard from the center frame.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Instinct Camera Replacement, Camera: adım 20, 1 resimden 1.
      • Once the motherboard is removed from the frame, use the pry tool to remove the camera.
      • Insert the pry bar between the camera and the frame then lift up.
      • The camera is held in by adhesive so it will require some force to remove.
      • You have now successfully removed the camera from your Samsung Instinct.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Patrick
75 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G13
4 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 1,244
