Ana içeriğe geç
Samsung Instinct LCD screen Replacement
Neye ihtiyacın var
  1. Samsung Instinct LCD screen Replacement, Battery: adım 1, 1 resimden 1.
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Instinct LCD screen Replacement: adım 2, 1 resimden 1.
    • Holding the phone firmly, use the notches to grip and lift up the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Instinct LCD screen Replacement, Back Case: adım 3, 1 resimden 1.
    • Remove the four 4.45mm screws at the corners of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Instinct LCD screen Replacement: adım 4, 2 resimden 1. Samsung Instinct LCD screen Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Instinct LCD screen Replacement: adım 5, 1 resimden 1.
    • Lift the casing off of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Instinct LCD screen Replacement, Antenna: adım 6, 1 resimden 1.
    • With the screws removed, locate the antenna.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Instinct LCD screen Replacement: adım 7, 1 resimden 1.
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Instinct LCD screen Replacement: adım 8, 1 resimden 1.
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Instinct LCD screen Replacement: adım 9, 1 resimden 1.
    • Gently lift up on the antenna and remove it from the back of the device.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Instinct LCD screen Replacement, Front Case: adım 10, 1 resimden 1.
    • Remove the two 3.50mm screws connecting the motherboard to the case.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Instinct LCD screen Replacement: adım 11, 3 resimden 1. Samsung Instinct LCD screen Replacement: adım 11, 3 resimden 2. Samsung Instinct LCD screen Replacement: adım 11, 3 resimden 3.
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Instinct LCD screen Replacement: adım 12, 1 resimden 1.
    • Lift out the top right ribbon from its slot on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Instinct LCD screen Replacement: adım 13, 2 resimden 1. Samsung Instinct LCD screen Replacement: adım 13, 2 resimden 2.
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Instinct LCD screen Replacement: adım 14, 1 resimden 1.
    • Lift the motherboard away from the front casing.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Instinct LCD screen Replacement: adım 15, 1 resimden 1.
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Instinct LCD screen Replacement, LCD screen: adım 16, 1 resimden 1.
    • Using the plastic opener tool, detach the ribbon located on the bottom of the phone below the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Instinct LCD screen Replacement: adım 17, 1 resimden 1.
    • Lift the microchip (located at the bottom of the phone) and insert the plastic opener tool under the screen.
    • Lift up the screen. The microchip is attached to the screen and will be lifted out with the screen.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung Instinct LCD screen Replacement: adım 18, 1 resimden 1.
    • After lifting out the LCD screen, the screen and its housing should be separated as shown.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick
75 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G13
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 1,921
