Ana içeriğe geç
Samsung Instinct Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Instinct Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Instinct Motherboard Replacement: adım 2, 1 resimden 1.
    • Holding the phone firmly, use the notches to grip and lift up the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Instinct Motherboard Replacement, Back Case: adım 3, 1 resimden 1.
    • Remove the four 4.45mm screws at the corners of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Instinct Motherboard Replacement: adım 4, 2 resimden 1. Samsung Instinct Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Instinct Motherboard Replacement: adım 5, 1 resimden 1.
    • Lift the casing off of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Instinct Motherboard Replacement, Antenna: adım 6, 1 resimden 1.
    • With the screws removed, locate the antenna.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Instinct Motherboard Replacement: adım 7, 1 resimden 1.
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Instinct Motherboard Replacement: adım 8, 1 resimden 1.
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Instinct Motherboard Replacement: adım 9, 1 resimden 1.
    • Gently lift up on the antenna and remove it from the back of the device.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Instinct Motherboard Replacement, Front Case: adım 10, 1 resimden 1.
    • Remove the two 3.50mm screws connecting the motherboard to the case.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Instinct Motherboard Replacement: adım 11, 3 resimden 1. Samsung Instinct Motherboard Replacement: adım 11, 3 resimden 2. Samsung Instinct Motherboard Replacement: adım 11, 3 resimden 3.
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Instinct Motherboard Replacement: adım 12, 1 resimden 1.
    • Lift out the top right ribbon from its slot on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Instinct Motherboard Replacement: adım 13, 2 resimden 1. Samsung Instinct Motherboard Replacement: adım 13, 2 resimden 2.
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Instinct Motherboard Replacement: adım 14, 1 resimden 1.
    • Lift the motherboard away from the front casing.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Instinct Motherboard Replacement: adım 15, 1 resimden 1.
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Instinct Motherboard Replacement, Motherboard: adım 16, 3 resimden 1. Samsung Instinct Motherboard Replacement, Motherboard: adım 16, 3 resimden 2. Samsung Instinct Motherboard Replacement, Motherboard: adım 16, 3 resimden 3.
    • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
    • There are three strips total: one on the right, left, and top of the phone.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Instinct Motherboard Replacement: adım 17, 1 resimden 1.
    • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung Instinct Motherboard Replacement: adım 18, 1 resimden 1.
    • Using the plastic opener tool, remove the speaker from its setting.
    • Pry where the wire enters the speaker.
    • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
    FixBot'a Sor
    Yorum Ekle
  19. Samsung Instinct Motherboard Replacement: adım 19, 1 resimden 1.
    • Gently lift the motherboard from the center frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Brayton
49 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G13
4 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 5,432
