Ana içeriğe geç
Samsung Instinct Speaker Replacement
Neye ihtiyacın var
  1. Samsung Instinct Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Speaker Replacement: adım 2, 1 resimden 1.
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Speaker Replacement, Back Case: adım 3, 1 resimden 1.
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Speaker Replacement: adım 4, 2 resimden 1. Samsung Instinct Speaker Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Speaker Replacement: adım 5, 1 resimden 1.
    • Lift the casing off of the phone.
  6. Samsung Instinct Speaker Replacement, Antenna: adım 6, 1 resimden 1.
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Speaker Replacement: adım 7, 1 resimden 1.
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Speaker Replacement: adım 8, 1 resimden 1.
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Speaker Replacement: adım 9, 1 resimden 1.
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Speaker Replacement, Front Case: adım 10, 1 resimden 1.
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Speaker Replacement: adım 11, 3 resimden 1. Samsung Instinct Speaker Replacement: adım 11, 3 resimden 2. Samsung Instinct Speaker Replacement: adım 11, 3 resimden 3.
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Speaker Replacement: adım 12, 1 resimden 1.
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Speaker Replacement: adım 13, 2 resimden 1. Samsung Instinct Speaker Replacement: adım 13, 2 resimden 2.
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Speaker Replacement: adım 14, 1 resimden 1.
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Speaker Replacement: adım 15, 1 resimden 1.
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
  16. Samsung Instinct Speaker Replacement, Speaker: adım 16, 1 resimden 1.
    • Using tweezers to grasp the pins of the speaker, gently lift the speaker up out of its setting in the front case.
Sonuç
Brayton
49 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G13
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 764
