Ana içeriğe geç
Samsung Jack Antenna Replacement
Neye ihtiyacın var
  1. Samsung Jack Antenna Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Antenna Replacement: adım 2, 1 resimden 1.
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Antenna Replacement, Rear Case: adım 3, 1 resimden 1.
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Antenna Replacement: adım 4, 3 resimden 1. Samsung Jack Antenna Replacement: adım 4, 3 resimden 2. Samsung Jack Antenna Replacement: adım 4, 3 resimden 3.
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Antenna Replacement: adım 5, 1 resimden 1.
    • Lift the rear case off of the phone.
  6. Samsung Jack Antenna Replacement, Antenna: adım 6, 1 resimden 1.
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. Samsung Jack Antenna Replacement: adım 7, 3 resimden 1. Samsung Jack Antenna Replacement: adım 7, 3 resimden 2. Samsung Jack Antenna Replacement: adım 7, 3 resimden 3.
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
Sonuç
Paul Piller
56 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G57
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,339
