Ana içeriğe geç
Samsung Jack Motherboard Replacement
Neye ihtiyacın var
    1. Samsung Jack Motherboard Replacement, Battery: adım 1, 1 resimden 1.
      • Slide the battery cover downwards with pressure focused on the center of the cover.
      • Lift the cover off of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Jack Motherboard Replacement: adım 2, 1 resimden 1.
      • Grasp the bottom left and right corners of the battery and lift it from its housing.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Jack Motherboard Replacement, Rear Case: adım 3, 1 resimden 1.
      • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Jack Motherboard Replacement: adım 4, 3 resimden 1. Samsung Jack Motherboard Replacement: adım 4, 3 resimden 2. Samsung Jack Motherboard Replacement: adım 4, 3 resimden 3.
      • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool in between the front and rear cases.
      • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Jack Motherboard Replacement: adım 5, 1 resimden 1.
      • Lift the rear case off of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Jack Motherboard Replacement, Speaker: adım 6, 1 resimden 1.
      • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
      • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Jack Motherboard Replacement: adım 7, 2 resimden 1. Samsung Jack Motherboard Replacement: adım 7, 2 resimden 2.
      • Use the spudger to detach the speaker ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Jack Motherboard Replacement: adım 8, 1 resimden 1.
      • Lift the speaker out of its compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Jack Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
      • Remove the power and volume buttons on the right side of the Motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Jack Motherboard Replacement: adım 10, 2 resimden 1. Samsung Jack Motherboard Replacement: adım 10, 2 resimden 2.
      • Use a spudger to detach the camera ribbon cable.
      • Lift the camera off of the Motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Jack Motherboard Replacement: adım 11, 2 resimden 1. Samsung Jack Motherboard Replacement: adım 11, 2 resimden 2.
      • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Jack Motherboard Replacement: adım 12, 3 resimden 1. Samsung Jack Motherboard Replacement: adım 12, 3 resimden 2. Samsung Jack Motherboard Replacement: adım 12, 3 resimden 3.
      • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
      • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Jack Motherboard Replacement: adım 13, 2 resimden 1. Samsung Jack Motherboard Replacement: adım 13, 2 resimden 2.
      • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
      • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
      • Use a spudger to disconnect the Motherboard ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Jack Motherboard Replacement: adım 14, 1 resimden 1.
      • Lift the Motherboard off of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jaime Serrano
59 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G57
4 Üyeler
70 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 34
Her zaman: 2,534
