Ana içeriğe geç
Samsung Jack Speaker Replacement
Neye ihtiyacın var
  1. Samsung Jack Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Jack Speaker Replacement: adım 2, 1 resimden 1.
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Jack Speaker Replacement, Rear Case: adım 3, 1 resimden 1.
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Jack Speaker Replacement: adım 4, 3 resimden 1. Samsung Jack Speaker Replacement: adım 4, 3 resimden 2. Samsung Jack Speaker Replacement: adım 4, 3 resimden 3.
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Jack Speaker Replacement: adım 5, 1 resimden 1.
    • Lift the rear case off of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Jack Speaker Replacement, Speaker: adım 6, 1 resimden 1.
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Jack Speaker Replacement: adım 7, 2 resimden 1. Samsung Jack Speaker Replacement: adım 7, 2 resimden 2.
    • Use the spudger to detach the speaker ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Jack Speaker Replacement: adım 8, 1 resimden 1.
    • Lift the speaker out of its compartment.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paul Piller
56 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G57
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 2,073
