Ana içeriğe geç
Samsung Juke Camera/Speaker Replacement
Neye ihtiyacın var
  1. Samsung Juke Camera/Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Camera/Speaker Replacement: adım 2, 2 resimden 1. Samsung Juke Camera/Speaker Replacement: adım 2, 2 resimden 2.
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Camera/Speaker Replacement, Camera/Speaker: adım 3, 1 resimden 1.
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Camera/Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Camera/Speaker Replacement: adım 5, 3 resimden 1. Samsung Juke Camera/Speaker Replacement: adım 5, 3 resimden 2. Samsung Juke Camera/Speaker Replacement: adım 5, 3 resimden 3.
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Camera/Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Camera/Speaker Replacement: adım 7, 2 resimden 1. Samsung Juke Camera/Speaker Replacement: adım 7, 2 resimden 2.
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Camera/Speaker Replacement: adım 8, 2 resimden 1. Samsung Juke Camera/Speaker Replacement: adım 8, 2 resimden 2.
    • Use the iFixit opening tool to gently pry the camera/speaker off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Renee Kuzniar
82 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-18, Maness Spring 2010 Cal Poly, Team 6-18, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G18
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,514
