Ana içeriğe geç
Samsung Juke Click Wheel Replacement
Neye ihtiyacın var
    1. Samsung Juke Click Wheel Replacement, Battery: adım 1, 1 resimden 1.
      • Press and hold down the button on the bottom side of the phone with your finger.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Juke Click Wheel Replacement: adım 2, 2 resimden 1. Samsung Juke Click Wheel Replacement: adım 2, 2 resimden 2.
      • While holding the button down, remove the back cover of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Juke Click Wheel Replacement, Camera/Speaker: adım 3, 1 resimden 1.
      • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Juke Click Wheel Replacement: adım 4, 1 resimden 1.
      • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Juke Click Wheel Replacement: adım 5, 3 resimden 1. Samsung Juke Click Wheel Replacement: adım 5, 3 resimden 2. Samsung Juke Click Wheel Replacement: adım 5, 3 resimden 3.
      • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
      • Failure to open USB port cover at this stage may result in damaging the device.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Juke Click Wheel Replacement: adım 6, 1 resimden 1.
      • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Juke Click Wheel Replacement: adım 7, 2 resimden 1. Samsung Juke Click Wheel Replacement: adım 7, 2 resimden 2.
      • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
      • Practice caution to prevent damage to the attaching ribbon.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Juke Click Wheel Replacement: adım 8, 2 resimden 1. Samsung Juke Click Wheel Replacement: adım 8, 2 resimden 2.
      • Use the iFixit opening tool to gently pry the camera/speaker off.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Juke Click Wheel Replacement, Motherboard: adım 9, 2 resimden 1. Samsung Juke Click Wheel Replacement, Motherboard: adım 9, 2 resimden 2.
      • Use the iFixit opening tool to remove the yellow tab on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Juke Click Wheel Replacement: adım 10, 2 resimden 1. Samsung Juke Click Wheel Replacement: adım 10, 2 resimden 2.
      • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Juke Click Wheel Replacement: adım 11, 3 resimden 1. Samsung Juke Click Wheel Replacement: adım 11, 3 resimden 2. Samsung Juke Click Wheel Replacement: adım 11, 3 resimden 3.
      • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
      • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Juke Click Wheel Replacement, Keyboard: adım 12, 3 resimden 1. Samsung Juke Click Wheel Replacement, Keyboard: adım 12, 3 resimden 2. Samsung Juke Click Wheel Replacement, Keyboard: adım 12, 3 resimden 3.
      • Open/swivel the phone so the back of the LCD panel is visible.
      • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
      • A moderate amount of force may need to be applied.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Juke Click Wheel Replacement, Click Wheel: adım 13, 2 resimden 1. Samsung Juke Click Wheel Replacement, Click Wheel: adım 13, 2 resimden 2.
      • Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
      • Remove six 3.5 mm screws from the back of the device using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Juke Click Wheel Replacement: adım 14, 3 resimden 1. Samsung Juke Click Wheel Replacement: adım 14, 3 resimden 2. Samsung Juke Click Wheel Replacement: adım 14, 3 resimden 3.
      • Using a generous amount of force, use your hands to pry loose the casing from the LCD panel.
      • If necessary, use the iFixit opening tool to completely free the casing.
      • Be careful not to sever the wire connecting the outer casing to the display board.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Juke Click Wheel Replacement: adım 15, 3 resimden 1. Samsung Juke Click Wheel Replacement: adım 15, 3 resimden 2. Samsung Juke Click Wheel Replacement: adım 15, 3 resimden 3.
      • Using the iFixit opening tool, remove the click wheel from the board.
      • After you have freed the edges, use the spudger to release the clip holding it flush to the board.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Juke Click Wheel Replacement: adım 16, 3 resimden 1. Samsung Juke Click Wheel Replacement: adım 16, 3 resimden 2. Samsung Juke Click Wheel Replacement: adım 16, 3 resimden 3.
      • Unlock the ribbon connection by pressing down on the black clip.
      • Carefully pull the click wheel away from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Turner
107 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-18, Maness Spring 2010 Cal Poly, Team 6-18, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G18
3 Üyeler
72 adet Kılavuz yazıldı
1Rehber Yorum
All I have to say is: THANK YOU!
My juke's click wheel got stuck, which was draining my battery. I followed the incredibly easy to understand instructions and pictures and was able to free my click wheel. I cleaned the wheel and put my phone back together by going backward though the instructions, turned on my phone, and IT WORKED PERFECTLY. This saved my from having to buy a new, large and extremely expensive phone.
Thank You so much for these great, step-by-step instructions!
Rachel Krebs - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 3,849
