Ana içeriğe geç
Samsung Juke SCH-u470 Keyboard Replacement
Neye ihtiyacın var
  1. Samsung Juke SCH-u470 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke SCH-u470 Keyboard Replacement: adım 2, 2 resimden 1. Samsung Juke SCH-u470 Keyboard Replacement: adım 2, 2 resimden 2.
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke SCH-u470 Keyboard Replacement, Camera/Speaker: adım 3, 1 resimden 1.
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke SCH-u470 Keyboard Replacement: adım 4, 1 resimden 1.
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke SCH-u470 Keyboard Replacement: adım 5, 3 resimden 1. Samsung Juke SCH-u470 Keyboard Replacement: adım 5, 3 resimden 2. Samsung Juke SCH-u470 Keyboard Replacement: adım 5, 3 resimden 3.
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke SCH-u470 Keyboard Replacement: adım 6, 1 resimden 1.
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke SCH-u470 Keyboard Replacement: adım 7, 2 resimden 1. Samsung Juke SCH-u470 Keyboard Replacement: adım 7, 2 resimden 2.
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke SCH-u470 Keyboard Replacement: adım 8, 2 resimden 1. Samsung Juke SCH-u470 Keyboard Replacement: adım 8, 2 resimden 2.
    • Use the iFixit opening tool to gently pry the camera/speaker off.
  9. Samsung Juke SCH-u470 Keyboard Replacement, Motherboard: adım 9, 2 resimden 1. Samsung Juke SCH-u470 Keyboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Use the iFixit opening tool to remove the yellow tab on the motherboard.
  10. Samsung Juke SCH-u470 Keyboard Replacement: adım 10, 2 resimden 1. Samsung Juke SCH-u470 Keyboard Replacement: adım 10, 2 resimden 2.
    • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
  11. Samsung Juke SCH-u470 Keyboard Replacement: adım 11, 3 resimden 1. Samsung Juke SCH-u470 Keyboard Replacement: adım 11, 3 resimden 2. Samsung Juke SCH-u470 Keyboard Replacement: adım 11, 3 resimden 3.
    • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
    • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
  12. Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: adım 12, 3 resimden 1. Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: adım 12, 3 resimden 2. Samsung Juke SCH-u470 Keyboard Replacement, Keyboard: adım 12, 3 resimden 3.
    • Open/swivel the phone so the back of the LCD panel is visible.
    • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
    • A moderate amount of force may need to be applied.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Renee Kuzniar
82 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-18, Maness Spring 2010 Cal Poly, Team 6-18, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G18
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,901
