Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Press and hold down the button on the bottom side of the phone with your finger.
While holding the button down, remove the back cover of the phone.
Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
Use the iFixit opening tool to remove the camera/speaker from the motherboard.
Use the iFixit opening tool to gently pry the camera/speaker off.
Use the iFixit opening tool to remove the yellow tab on the motherboard.
Use the iFixit opening tool to remove the other orange tab to free the motherboard.
To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
Open/swivel the phone so the back of the LCD panel is visible.
Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
Bir başkası bu kılavuzu tamamladı.
