Ana içeriğe geç
Samsung L100 Setting Knob Spring
Neye ihtiyacın var
  1. Samsung L100 Setting Knob Spring, Removing Back Cover: adım 1, 3 resimden 1. Samsung L100 Setting Knob Spring, Removing Back Cover: adım 1, 3 resimden 2. Samsung L100 Setting Knob Spring, Removing Back Cover: adım 1, 3 resimden 3.
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung L100 Setting Knob Spring: adım 2, 2 resimden 1. Samsung L100 Setting Knob Spring: adım 2, 2 resimden 2.
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung L100 Setting Knob Spring: adım 3, 3 resimden 1. Samsung L100 Setting Knob Spring: adım 3, 3 resimden 2. Samsung L100 Setting Knob Spring: adım 3, 3 resimden 3.
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung L100 Setting Knob Spring: adım 4, 1 resimden 1.
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung L100 Setting Knob Spring: adım 5, 1 resimden 1.
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung L100 Setting Knob Spring, Flash Circuit Board: adım 6, 1 resimden 1.
    • Remove the screws holding the circuit board.
    • After you remove the screws, carefully remove the circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung L100 Setting Knob Spring: adım 7, 2 resimden 1. Samsung L100 Setting Knob Spring: adım 7, 2 resimden 2.
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung L100 Setting Knob Spring: adım 8, 1 resimden 1.
    • Face camera towards you.
    • Remove the two screws from circuit board on the left side of the lens.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung L100 Setting Knob Spring: adım 9, 1 resimden 1.
    • Carefully hold up the circuit board, while it's still connected to the camera.
    • Remove all five screws that's on top of the camera.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung L100 Setting Knob Spring: adım 10, 3 resimden 1. Samsung L100 Setting Knob Spring: adım 10, 3 resimden 2. Samsung L100 Setting Knob Spring: adım 10, 3 resimden 3.
    • Carefully push up the top of the circuit board.
    • Pull up flash circuit board from top of camera.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung L100 Setting Knob Spring, Setting Knob Spring: adım 11, 1 resimden 1.
    • Face the bottom of the Flash Circuit board towards you.
    • Remove the one screw that's located on the left side of the lens.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung L100 Setting Knob Spring: adım 12, 1 resimden 1.
    • Take the flash circuit board and turn it over.
    • Remove the plastic setting knob.
    • Make sure to keep copper spring inside of the slot.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung L100 Setting Knob Spring: adım 13, 3 resimden 1. Samsung L100 Setting Knob Spring: adım 13, 3 resimden 2. Samsung L100 Setting Knob Spring: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Take out and replace the Setting Knob Spring with tweezers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
andyhe
81 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G17
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 53
Her zaman: 3,529
