Ana içeriğe geç
Samsung L100 camera lens replacement
Neye ihtiyacın var
  1. Samsung L100 camera lens replacement, Removing Back Cover: adım 1, 3 resimden 1. Samsung L100 camera lens replacement, Removing Back Cover: adım 1, 3 resimden 2. Samsung L100 camera lens replacement, Removing Back Cover: adım 1, 3 resimden 3.
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 camera lens replacement: adım 2, 2 resimden 1. Samsung L100 camera lens replacement: adım 2, 2 resimden 2.
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 camera lens replacement: adım 3, 3 resimden 1. Samsung L100 camera lens replacement: adım 3, 3 resimden 2. Samsung L100 camera lens replacement: adım 3, 3 resimden 3.
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 camera lens replacement: adım 4, 1 resimden 1.
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 camera lens replacement: adım 5, 1 resimden 1.
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 camera lens replacement, Camera Lens: adım 6, 1 resimden 1.
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  7. Samsung L100 camera lens replacement: adım 7, 1 resimden 1.
    • Remove green tape from ribbon.
  8. Samsung L100 camera lens replacement: adım 8, 2 resimden 1. Samsung L100 camera lens replacement: adım 8, 2 resimden 2.
    • Remove four screws around lens.
  9. Samsung L100 camera lens replacement: adım 9, 1 resimden 1.
    • Use spudger to remove ribbon connecting the circuit board from lens.
  10. Samsung L100 camera lens replacement: adım 10, 1 resimden 1.
    • Remove lens from camera.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Adriel
123 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G17
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 30
Her zaman: 10,112
