Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove batteries before you disassemble the remote Use a case opening tool to gently split the upper and lower case Work around the entire case until the 2 halves come apart completely
    • Remove batteries before you disassemble the remote
    • Use a case opening tool to gently split the upper and lower case
    • Work around the entire case until the 2 halves come apart completely
  2. Release the circuit board by gently pushing the plastic tab away from the board Use minimal force to avoid breaking it
    • Release the circuit board by gently pushing the plastic tab away from the board
    • Use minimal force to avoid breaking it
    • Lift circuit board off top cover to expose the rubber button membrane
    • Lift off the rubber button membrane
  3. During reassembly make sure that you correctly place the battery cover retainer on the read case During reassembly make sure that you correctly place the battery cover retainer on the read case
    • During reassembly make sure that you correctly place the battery cover retainer on the read case
  4. When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover
    • When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Richdave
29.826 İtibar
30 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
287 Üyeler
818 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 39
Son 30 Gün: 174
Her zaman: 24,834
