Ana içeriğe geç
Samsung LN-T5265F T-Con Board Replacement
Neye ihtiyacın var
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: adım 1, 1 resimden 1.
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: adım 3, 2 resimden 1. Samsung LN-T5265F T-Con Board Replacement, Rear Case: adım 3, 2 resimden 2.
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: adım 4, 2 resimden 1. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: adım 4, 2 resimden 2.
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
  4. Samsung LN-T5265F T-Con Board Replacement: adım 5, 1 resimden 1.
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
  5. Samsung LN-T5265F T-Con Board Replacement: adım 6, 1 resimden 1.
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Steven Carlton
606 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 10,057
