Ana içeriğe geç
Samsung Level Box Mini Battery Replacement
Neye ihtiyacın var
  1. Samsung Level Box Mini Battery Replacement, Battery: adım 1, 2 resimden 1. Samsung Level Box Mini Battery Replacement, Battery: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
  2. Samsung Level Box Mini Battery Replacement: adım 2, 1 resimden 1.
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
  3. Samsung Level Box Mini Battery Replacement: adım 3, 1 resimden 1.
    • Using the plastic opening tool, remove the batteries from the device.
Sonuç
To reassemble your device, follow all the instructions in the reverse order. Use adhesive to stick the rubber back onto the bottom of the device.
9 farklı kişi bu kılavuzu tamamladı.
dylan weiss
134 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Kass Spring 2017 USF Tampa, Team 1-4, Kass Spring 2017 üyesi
USFT-KASS-S17S1G4
5 Üyeler
4 adet Kılavuz yazıldı
5Kılavuz Yorumları
Did all above but still wont switch on..batt are ok and power gets to the battery points…what could be wrong…
dslotman5 - Yanıt Paylaş
I want to replace pcb of this device how to find it??
faraz siddiqui - Yanıt Paylaş
I want to replace PCB of this device suggest me where to find?
The "parts needed" list has a search for the battery misspelled in "Samsung".
Jim Plosay - Yanıt Paylaş
What kind of batterries should get ?
Aldo Eliezer Rivera Sizzo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 90
Her zaman: 10,064
