Ana içeriğe geç
Samsung ML2510 Power Button Replacement
Neye ihtiyacın var
  1. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 1. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 2. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 3.
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Power Button Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Power Button Replacement: adım 3, 3 resimden 1. Samsung ML2510 Power Button Replacement: adım 3, 3 resimden 2. Samsung ML2510 Power Button Replacement: adım 3, 3 resimden 3.
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Power Button Replacement, Power Button: adım 4, 3 resimden 1. Samsung ML2510 Power Button Replacement, Power Button: adım 4, 3 resimden 2. Samsung ML2510 Power Button Replacement, Power Button: adım 4, 3 resimden 3.
    • Remove the front panel by gently separating the holes on the panel from the pegs attached to the main printer body.
  5. Samsung ML2510 Power Button Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove both 1" screws on the front face of the printer.
  6. Samsung ML2510 Power Button Replacement: adım 6, 3 resimden 1. Samsung ML2510 Power Button Replacement: adım 6, 3 resimden 2. Samsung ML2510 Power Button Replacement: adım 6, 3 resimden 3.
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the last step to free the opposite side of the top panel.
    • Lift the top panel from the front to remove it entirely.
    • Turn over the top panel to reveal the button on the underside of the panel.
  7. Samsung ML2510 Power Button Replacement: adım 7, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove both 1" screws that secure the button to the underside of the top panel.
  8. Samsung ML2510 Power Button Replacement: adım 8, 2 resimden 1. Samsung ML2510 Power Button Replacement: adım 8, 2 resimden 2.
    • Remove the clear plastic piece and the orange button from the panel.
    • Remove the orange button and the spring from the clear plastic holder.
    • Replace the button and reassemble the printer following the directions in reverse order.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
bbaustin
268 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G18
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 3,128
