Ana içeriğe geç
Samsung ML2510 Rear Cooling Fan Replacement
Neye ihtiyacın var
    1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 2. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 3.
      • Remove the top hinged panel by taking out the pins at the bottom of this panel.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung ML2510 Rear Cooling Fan Replacement: adım 2, 1 resimden 1.
      • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung ML2510 Rear Cooling Fan Replacement: adım 3, 3 resimden 1. Samsung ML2510 Rear Cooling Fan Replacement: adım 3, 3 resimden 2. Samsung ML2510 Rear Cooling Fan Replacement: adım 3, 3 resimden 3.
      • Gently lift the top panel while simultaneously pulling off the back panel.
      • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: adım 4, 2 resimden 1. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: adım 4, 2 resimden 2.
      • Once the fan is detached, unplug the fan from the circuit board.
      • Slide the fan's wiring through the anchored slit.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung ML2510 Rear Cooling Fan Replacement: adım 5, 1 resimden 1.
      • With the new fan, thread the wiring through the old fan's slit.
      • Reconnect the fan by plugging it back into the circuit board.
      • Reattach the back panel following these instructions in reverse order.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
bbaustin
268 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G18
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 43
Her zaman: 3,852
