Ana içeriğe geç
Samsung ML2510 Rear Cooling Fan Replacement
Neye ihtiyacın var
  1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 1. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 2. Samsung ML2510 Rear Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: adım 1, 3 resimden 3.
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Rear Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Rear Cooling Fan Replacement: adım 3, 3 resimden 1. Samsung ML2510 Rear Cooling Fan Replacement: adım 3, 3 resimden 2. Samsung ML2510 Rear Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: adım 4, 2 resimden 1. Samsung ML2510 Rear Cooling Fan Replacement, Rear Cooling Fan: adım 4, 2 resimden 2.
    • Once the fan is detached, unplug the fan from the circuit board.
    • Slide the fan's wiring through the anchored slit.
  5. Samsung ML2510 Rear Cooling Fan Replacement: adım 5, 1 resimden 1.
    • With the new fan, thread the wiring through the old fan's slit.
    • Reconnect the fan by plugging it back into the circuit board.
    • Reattach the back panel following these instructions in reverse order.
Bitiş Çizgisi
bbaustin
268 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G18
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
My printer is in this state currently. What is the type of fan (brand/specs) that needs to be installed? And perhaps also, where does one obtain such a fan?
Bax Bagatelli - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,339
