Ana içeriğe geç
Samsung MV900F Flash Bulb Assembly Replacement
Neye ihtiyacın var
  1. Samsung MV900F Flash Bulb Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung MV900F Flash Bulb Assembly Replacement: adım 2, 1 resimden 1.
    • Push the blue battery holder up in the direction of the arrow.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung MV900F Flash Bulb Assembly Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the battery slot.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung MV900F Flash Bulb Assembly Replacement, Screen: adım 4, 2 resimden 1. Samsung MV900F Flash Bulb Assembly Replacement, Screen: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the four rubber screw covers.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung MV900F Flash Bulb Assembly Replacement: adım 5, 2 resimden 1. Samsung MV900F Flash Bulb Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung MV900F Flash Bulb Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the back casing by just carefully pulling the casing off of the camera.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung MV900F Flash Bulb Assembly Replacement: adım 7, 1 resimden 1.
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung MV900F Flash Bulb Assembly Replacement: adım 8, 1 resimden 1.
    • Use plastic opening tool to disconnect screen connector from the control board.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung MV900F Flash Bulb Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the old screen.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung MV900F Flash Bulb Assembly Replacement, Lens Assembly: adım 10, 1 resimden 1.
    • Remove the 2.381 mm screw with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung MV900F Flash Bulb Assembly Replacement: adım 11, 1 resimden 1.
    • Use the plastic opening tool to remove the silver metal lens cover.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung MV900F Flash Bulb Assembly Replacement: adım 12, 1 resimden 1.
    • Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung MV900F Flash Bulb Assembly Replacement: adım 13, 1 resimden 1.
    • From the front of the camera, push the lens through the back of the camer.a
    FixBot'a Sor
    Yorum Ekle
  14. Samsung MV900F Flash Bulb Assembly Replacement: adım 14, 2 resimden 1. Samsung MV900F Flash Bulb Assembly Replacement: adım 14, 2 resimden 2.
    • Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung MV900F Flash Bulb Assembly Replacement: adım 15, 2 resimden 1. Samsung MV900F Flash Bulb Assembly Replacement: adım 15, 2 resimden 2.
    • Remove the lens assembly from the camera.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung MV900F Flash Bulb Assembly Replacement, Flash Bulb Assembly: adım 16, 1 resimden 1.
    • Remove the 2.381 mm screw that is holding the copper to the control board with a Phillips #00 screw driver.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung MV900F Flash Bulb Assembly Replacement: adım 17, 1 resimden 1.
    • Use tweezers to pull copper connector from the control board.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung MV900F Flash Bulb Assembly Replacement: adım 18, 1 resimden 1.
    • Use the plastic opening tool to pry the control board up, thus allowing the flash bulb assembly to be removed.
    FixBot'a Sor
    Yorum Ekle
  19. Samsung MV900F Flash Bulb Assembly Replacement: adım 19, 1 resimden 1.
    • Beginning with the battery on the side, gently pull upwards to remove the entire flash bulb assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Justin Smith
122 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 49
Her zaman: 732
