Ana içeriğe geç
Samsung MV900F Lens Assembly Replacement
Neye ihtiyacın var
  1. Samsung MV900F Lens Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Lens Assembly Replacement: adım 2, 1 resimden 1.
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Lens Assembly Replacement: adım 3, 1 resimden 1.
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Lens Assembly Replacement, Screen: adım 4, 2 resimden 1. Samsung MV900F Lens Assembly Replacement, Screen: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Lens Assembly Replacement: adım 5, 2 resimden 1. Samsung MV900F Lens Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Lens Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Lens Assembly Replacement: adım 7, 1 resimden 1.
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Lens Assembly Replacement: adım 8, 1 resimden 1.
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Lens Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the old screen.
  10. Samsung MV900F Lens Assembly Replacement, Lens Assembly: adım 10, 1 resimden 1.
    • Remove the 2.381 mm screw with a Phillips #00 screwdriver.
  11. Samsung MV900F Lens Assembly Replacement: adım 11, 1 resimden 1.
    • Use the plastic opening tool to remove the silver metal lens cover.
  12. Samsung MV900F Lens Assembly Replacement: adım 12, 1 resimden 1.
    • Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
  13. Samsung MV900F Lens Assembly Replacement: adım 13, 1 resimden 1.
    • From the front of the camera, push the lens through the back of the camer.a
  14. Samsung MV900F Lens Assembly Replacement: adım 14, 2 resimden 1. Samsung MV900F Lens Assembly Replacement: adım 14, 2 resimden 2.
    • Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
  15. Samsung MV900F Lens Assembly Replacement: adım 15, 2 resimden 1. Samsung MV900F Lens Assembly Replacement: adım 15, 2 resimden 2.
    • Remove the lens assembly from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ethan Rowland
216 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 867
