Giriş
This guide will instruct you on removing the camera from the Samsung Mythic SGH-a897 motherboard. To successfully remove the camera from the motherboard, the iFixit Opening Tool should be used to pry the camera and camera cable from the motherboard.
Neye ihtiyacın var
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
